The error you are getting is mysql related. Did you try to run that query on the mysql console? How did it go? Same error?
Try stopping the zabbix_server and then run the query. If it works, you definally needs to tune the mysql. If it dosent, try tuning and see if it does.
That size seems too small. I think im using about 16G and i have only 500nvps.
