I setup Zabbix snmp trap and host name shows up as <UNKNOWN> under "Latest Data"
Outcome:
I have created a host called snmptraps with ip 127.0.0.1 and assigned the following item to the host:
Type: Zabbix Trapper
Key: snmptraps
Type of information: Character
Any snmp traps that I sent to Zabbix shows up as <UNKNOWN>. Can someone help me with this please?
Zabbix Version: 2.0.3
snmptrap.sh:
Thanks.
# snmptrap -Ci -v 2c -c public localhost "" "NET-SNMP-MIB::netSnmpExperimental" NET-SNMP-MIB::netSnmpExperimental s "test15"
2012.Oct.15 17:22:31 <UNKNOWN> "test15" NET-SNMP-MIB::netSnmpExperimental
Key: snmptraps
snmptrap.sh:
ZABBIX_SERVER="localhost"; ZABBIX_PORT="10051"; ZABBIX_SENDER="/usr/local/bin/zabbix_sender"; KEY="snmptraps"; HOST="snmptraps"; # END OF CONFIGURATION read hostname read ip read uptime read oid read address read community read enterprise oid=`echo $oid|cut -f2 -d' '` address=`echo $address|cut -f2- -d' '` community=`echo $community|cut -f2 -d' '` enterprise=`echo $enterprise|cut -f2 -d' '` oid=`echo $oid|cut -f11 -d'.'` community=`echo $community|cut -f2 -d'"'` str="$hostname $address $community $enterprise $oid" $ZABBIX_SENDER -z $ZABBIX_SERVER -p $ZABBIX_PORT -s $HOST -k $KEY -o "$str"
