I am new to zabbix (using the latest build 2.0.3) and trying to setup multiple locations with devices behind the routers.
Like:
Site1 : Router -> Switch1
--------------> Switch2
--------------> Switch3
Site2 : Router -> Switch1
I setup a template called routers and added all routers to it. Then a group called switches and added the switches to it.
Now I liked to setup a dependency for the switches to point back to the router template in the template switches, but I get an error that the switch is not in the router template.
Am I doing something wrong, or is there a better way for this setup? I would just like to not get an email for every device at a site when the router goes offline.
Thanks for your time.
Like:
. Each system definitely has its strong suit and I definitely agree that dependencies are sometimes overly complex in Zabbix.
