Zabbix architecture advice for AWS
  • philipgeraldtaylor
    • Oct 2012
    Hi there, been using Zabbix for a few months now and loving it
    Am running a basic 2.0.2 server / agent setup on Debian but want to move the server to AWS and use the pfSense firewall/s to proxy (v1.8.n) over a VPN to an AWS VPC
    Also running Java Gateway, SNMP and Orabbix with some custom stuff - very ordinary setup am sure
    Have heard of Mikoomi but it kind of implies (?) you need to run an Appliance which I would prefer not to do since it has limited capabilities and I want the full server
    I guess my question is which Amazon EC2 AMI distro to use for best success and which cloud model?
    I suspect the latter will be a private VPC with a VPN but would really appreciate any advice on the distro part too.
    Many thanks, Phil
  • Alex_SYB
    • Feb 2012
    • 133
    Bump on this I am looking at putting a node outside our corporate network
    trying to decide weather its a node or proxy, thinking former. Trying to think weather ec2 is the way to go or to get a VPS.
    Any one had any expereince with setting up zabbix on EC2 ?
    A
      • Oct 2012
      Update
      Many thanks, Phil
      Further to this, we're now using a proxy quite successfully and after some research into AWS VPC access via SSH, it looks like the better option will be a VPN to each of the corporate sites.
        • Oct 2012
        A
        Are you trying to monitor EC2 or monitor from EC2/AWS?
        • Alex_SYB
          • Feb 2012
          • 133
          I want to monitor from outside my network. so basically using ec2 as a vps provider ...
            • Oct 2012
            Same here so we're looking at a VPC/VPN for Zabbix server (public web / private db) to proxies on our various sites
