agent.ping Issue
  • bcarpio
    • Jun 2008
    • 96
    agent.ping Issue
    I'm doing A/B application deployments in EC2 so I am consistently deploying new app nodes in EC2. I use auto-registration so new nodes come up, puppet puts down the zabbix agent and config and they check in automatically to Zabbix server.
    However since my trigger is {Template_Linux:agent.ping.nodata(300)}=1} so once the systems come up they alert PROBLEM then go to OK.
    There has to be a creative way to make new nodes not alert and nodes that are really down to alert... I'm on Zabbix 2.x
  • bcarpio
    • Jun 2008
    • 96
    Resolved [agent.ping]
    I have changed the trigger to be:
    {Template_Linux:agent.ping.nodata(180)}=1 & {Template_Linux:agent.ping.last(0)}=1
    This now works, so once a node has checked in and reported data and then goes to nodata for 180 seconds send a trigger.
