I am having an issue with monitoring JMX over an active proxy. I am getting the following error:
Javagateway is running and its port is correctly set. I am fairly confident that it is not a proxy configuration issue because I am monitoring agent checks on the same machine through the proxy.
Is anyone aware of what
means?
28481:20121019:130911.354 In get_values() 28481:20121019:130911.355 In DCconfig_get_poller_items() poller_type:4 28481:20121019:130911.355 End of DCconfig_get_poller_items():0 28481:20121019:130911.355 End of get_values():0 28481:20121019:130911.355 java poller #2 spent 0.000489 seconds while updating 0 values 28481:20121019:130911.355 In DCconfig_get_poller_nextcheck() poller_type:4 28481:20121019:130911.355 End of DCconfig_get_poller_nextcheck():-1 28481:20121019:130911.356 sleeping for 5 seconds 28452:20121019:130911.356 Getting Java values failed: ZBX_TCP_READ() failed: [4] Interrupted system call 28452:20121019:130911.356 End of get_values_java() 28452:20121019:130911.356 Item [host:jmx["java.lang:type=Compilation",Name]] error: ZBX_TCP_READ() failed: [4] Interrupted system call 28452:20121019:130911.356 End of get_value():GATEWAY_ERROR 28452:20121019:130911.356 In deactivate_host() hostid:10301 itemid:41972 type:16 28452:20121019:130911.356 deactivate_host() errors_from:1350595261 available:2 28452:20121019:130911.356 query [txnlev:1] [begin;] 28452:20121019:130911.357 query [txnlev:1] [update hosts set jmx_error='ZBX_TCP_READ() failed: [4] Interrupted system call',jmx_disable_until=1350677411 where hostid=10301] 28452:20121019:130911.358 query [txnlev:1] [commit;] 28452:20121019:130911.359 End of deactivate_host() 28452:20121019:130911.360 End of get_values():1
