Zabbix 2.0.2 and log monitoring problem.
  • vesa
    • Apr 2012
    Hello all,
    I've been trying to create a item and a trigger to monitor our log-files. What I am trying to do - when there is 'ERROR' in the log it will send e-mail notification. In general all e-mail notifications work except not for this trigger.
    In agentd.conf
    ServerActive=<Zabbix_server_ip>:<server_port>
    Item:
    log[/opt/jboss-4.2.2.GA/conf/wrapper.log,ERROR,UTF-8,500]
    Trigger:
    {hostname:log[/opt/jboss-4.2.2.GA/conf/wrapper.log,ERROR,UTF-8,500].str(ERROR)}=1
    --> snip from log <--
    INFO | jvm 4 | 2012/10/23 13:07:22 | 13:07:22,625 ERROR [ServerThread] Worker thread initialization failure
    INFO | jvm 4 | 2012/10/23 13:07:52 | 13:07:52,884 ERROR [HTTPClientInvoker] Error creating SSL Socket Factory for client invoker.
    --> end of snip <--
    See attached images.
    What might cause this issue?
  • vesa
    • Apr 2012
    I fixed my issue with checking firewall settings. I forgot active checks use 10051 port. If some of you have same problem try following:
    On Zabbix Client Machine:
    telnet zabbix.server.org 10051
    On Zabbix Server Machine:
    telnet zabbix.client.org 10050
    Connections should be established, if not, check firewall settings.
