Proxy and simple checks icmpping(sec)
  • Thuist
    • Oct 2012
    We are monitoring several remote networks through proxies. What I cannot get clear however is the following:
    Can I use icmpping / icmppingsec on servers that are monitored through a proxy ?
    Proxies are supposed to support Simple Checks.
    If yes the question is who executes that simple check (icmpping) ? Is that done by the proxy ?
    any info appreciated.
    thanks
  • alledm
    • May 2012
    • 84
    If the host is monitored through a proxy, the check will be performed by the proxy itself.
    What I do is to create 2 hosts. one real one connected to the proxy (i.e. hostname.company.com, ip Y.Z.X.X), and a "dummy one" (i.e. hostname-ping.company.com ip Y.Z.X.X) which will then be checked by the main zabbix server.
