I have a JVM uptime JMX check stored as DELTA. This is monitored over a proxy every 30 seconds. The proxy is an active proxy and I made sure in the log that it is sending every 30 seconds.
The trigger goes off on the item when it is set to DELTA, but not when the trigger is referencing an AS-IS version. The server is receiving data:
However, the trigger is still going off:
The trigger:
The item:
name=JVM Uptime Delta
key=jmx["java.lang:type=Runtime","Uptime"]
update interval=30
store value=Delta (simple change)
28446:20121023:132855.568 In send_data_to_server ... 28446:20121023:132925.833 In send_data_to_server ...
2012.Oct.23 15:44:39 30077 2012.Oct.23 15:44:09 30150 2012.Oct.23 15:43:39 30034 2012.Oct.23 15:43:09 30078 2012.Oct.23 15:42:39 29926 2012.Oct.23 15:42:10 29225 2012.Oct.23 15:41:40 30082 2012.Oct.23 15:41:10 30082 2012.Oct.23 15:40:40 30089 2012.Oct.23 15:40:10 30190 2012.Oct.23 15:39:40 30018
23 Oct 2012 15:44:09 ProxyJMXTest is not reachable OK High 51s No 23 Oct 2012 15:43:00 ProxyJMXTest is not reachable PROBLEM High 1m 9s No 23 Oct 2012 15:42:10 ProxyJMXTest is not reachable OK High 50s No 23 Oct 2012 15:42:31 ProxyJMXTest is not reachable PROBLEM High 21s No 23 Oct 2012 15:41:40 ProxyJMXTest is not reachable OK High 51s No 23 Oct 2012 15:42:00 ProxyJMXTest is not reachable PROBLEM High 20s No 23 Oct 2012 15:41:10 ProxyJMXTest is not reachable OK High 50s No 23 Oct 2012 15:41:30 ProxyJMXTest is not reachable PROBLEM High 20s No 23 Oct 2012 15:40:40 ProxyJMXTest is not reachable OK High 50s No 23 Oct 2012 15:41:00 ProxyJMXTest is not reachable PROBLEM High 20s No 23 Oct 2012 15:40:10 ProxyJMXTest is not reachable OK High 50s No 23 Oct 2012 15:40:30 ProxyJMXTest is not reachable PROBLEM High 20s No 23 Oct 2012 15:39:40 ProxyJMXTest is not reachable OK High 50s No 23 Oct 2012 15:40:00 ProxyJMXTest is not reachable PROBLEM High 20s No 23 Oct 2012 15:39:09 ProxyJMXTest is not reachable OK High 51s No 23 Oct 2012 15:39:30 ProxyJMXTest is not reachable PROBLEM High 21s No
{HOSTNAME} is not reachable - {JMX Generic:jmx["java.lang:type=Runtime","Uptime"].nodata(45)}=1
update interval=30
