vbs help
  • Pablo
    • May 2006
    • 24
    vbs help
    I have created two UserParameter for w32:
    1)
    UserParameter=actlogin,"C:\Program Files\zabbix\actlogin.bat"
    It works right. No problem.
    2)
    UserParameter=username,cscript "C:\Program Files\zabbix\username.vbs" //nologo
    This vbs doesn´t work right. When I create the key (username) in the server I get Parameter usename is not supported. Any idea???
    This is the test script:
    option explicit
    dim net, rrr
    set net = createobject("wscript.network")
    rrr = "User: " & net.username
    set net = nothing
    wscript.echo rrr
    and this the zabbix_agentd.conf file (both script and configuration file are in the same directory):
    Server=192.168.201.35
    # Server port for sending active checks
    ServerPort=10051
    # Unique hostname. Required for active checks.
    Hostname=exchange
    # Listen port. Default is 10050
    ListenPort=10050
    # IP address to bind agent
    # If missing, bind to all available IPs
    #ListenIP=192.168.201.45
    # Number of pre-forked instances of zabbix_agentd.
    # Default value is 5
    # This parameter must be between 1 and 16
    StartAgents=5
    # How often refresh list of active checks. 2 minutes by default.
    #RefreshActiveChecks=120
    # Disable active checks. The agent will work in passive mode listening server.
    #DisableActive=1
    # Specifies debug level
    # 0 - debug is not created
    # 1 - critical information
    # 2 - error information
    # 3 - warnings (default)
    # 4 - for debugging (produces lots of information)
    DebugLevel=3
    # Name of PID file
    #PidFile=C:\Program Files/zabbix/zabbix_agentd.pid
    # Name of log file.
    # If not set, syslog will be used
    LogFile=C:\Program Files/zabbix/zabbix_agentd.log
    # Spend no more than Timeout seconds on processing
    # Must be between 1 and 30
    Timeout=3
    ##### Experimental options. Use with care ! #####
    # Get rid of sockets in TIME_WAIT state
    # This will set socket option SO_LINGER
    # NoTimeWait=1
    ##### End of experimental options
    # Format: "UserParameter='key','shell command'"
    # Note that shell command must not return empty string or EOL only
    #UserParameter=mysql.version,mysql -V
    #UserParameter=login,cscript //NoLogo c:\diskspace.vbs $1
    Thank you.
  • Pablo
    • May 2006
    • 24
    I have added de path and vbs works correctly;
    UserParameter=prueba,c:\windows\system32\cscript.e xe c:\scripts\username.vbs //nologo
