Complex trigger expression in low-level-descovery
  • DeepDiver
    • Apr 2011
    I have low-level-discovery rule of SNMPv2 type by SNMP OID ifDescr. Then I create item and trigger prototypes. I want that one trigger worked with GigabitEthernet interfaces and another one with TenGigabitEthernet interfaces, because there is different treshlods for ifHCIn/OutOctets for each.
    So I define the followin trigger prototype:
    Name:
    ifHCInOctets.{#SNMPVALUE} too high
    Expression:
    {Dynamic SNMP device:ifHCInOctets.["{#SNMPVALUE}"].avg(900)}>600000000
    But how to "filter" only GigabitEthernet? I tried to make expression this way:
    {Dynamic SNMP device:ifHCInOctets.["{#SNMPVALUE}"].avg(900)}>600000000 & {Dynamic SNMP device:IfDescr.regexp(^GigabitEthernet)}=1
    or
    {Dynamic SNMP device:ifHCInOctets. "{#SNMPVALUE}"].avg(900)}>600000000 & {{#SNMPVALUE}.regexp(^GigabitEthernet)}=1
    and many other variants. As a result, I receive error:
    Incorrect host name "#SNMPVALUE" provided in expression. Check expression part starting from <...>
    However I even can not save such expression.
    In another words - I want to use SNMPVALUE (ifDescr) in expression of trigger prototype.
  • DeepDiver
    • Apr 2011
    I found workaound myself.
    Create item prototype:
    Name - ifDescr.$1
    Key - ifDescr.["{#SNMPVALUE}"]
    SNMP OID - ifDescr.{#SNMPINDEX}
    It will be used just as keys to use with correct trigger depending GigabitEthernet or 10GigabitEthernet.
    Then create trigger prototype with following expression:
    {Dynamic SNMP device:ifHCInOctets.["{#SNMPVALUE}"].avg(900)}>600000000 & {Dynamic SNMP device:ifDescr.["{#SNMPVALUE}"].regexp(^GigabitEthernet)}=1
    And similar for 10GigabitInterfaces:
    {Dynamic SNMP device:ifHCInOctets.["{#SNMPVALUE}"].avg(900)}>6000000000 & {Dynamic SNMP device:ifDescr.["{#SNMPVALUE}"].regexp(^10GigabitEthernet)}=1
    Hope this will save somebody's time.
