Hi everyone,
Fairly new guy here trying to get my feet wet and understand how all of this hangs together. Managed to set up a host and get the agent running and reporting ok. Now trying to push some custom items into the database and seem to have run into a bit of a brick wall.
Running v. 2.0.3 of the sender and server, and have tried every combination of things I can think of, and yet the sender keeps coming back with failed when I try to push a new value in.
Item is configured as "zabbix trapper", host is working OK otherwise. tried using the agent config and putting the server on the command line with -z, and nothing seems to work. Even tried to running the sender on the server itself with -z 127.0.0.1 and it still fails.
Item config:
Host: test
Type: Zabbix Trapper
Key: hwsensors.temp
Type of Information: Numeric (float)
Units: C
Allowed Hosts: (blank)
Status: Enabled
Trapper is listening on all interfaces:
# netstat -ln | grep 10051
tcp 0 0 0.0.0.0:10051 0.0.0.0:* LISTEN
and yet...
# zabbix_sender -z 127.0.0.1 -s test -k hwsensors.temp -o 1.0
info from server: "Processed 0 Failed 1 Total 1 Seconds spent 0.000040"
sent: 1; skipped: 0; total: 1
this doesn't work either, just as a test.
info from server: "Processed 0 Failed 1 Total 1 Seconds spent 0.000044"
Any ideas where I might be going wrong? The eventual plan is to use the sender to bulk load a bunch of items, but currently I can't even get it to send even a single one.
Item config:
Host: test
Key: hwsensors.temp
Units: C
Status: Enabled
and yet...
