Web scenarios execution info required
  • vinayak.mdesai
    • Oct 2012
    Hi all,
    If I create 10 scenarios of web monitoring, will they execute in parallel or sequential?
    Thanks in advance
    -Vinayak
  • BDiE8VNy
    • Apr 2010
    • 680
    It depends.
    A single poller loops sequencially through all scenarios where 'nextcheck' value is lower or euqal current time.
    In case there are multiple http pollers configured, there is a chance that scenarios get executed at the same time by different pollers (e.g. scenarios with same 'nextcheck' values).
    Scenarios are evenly distrubuted over multiple pollers similar to this example:
    zabbix=# SELECT httptestid, MOD(httptestid,4) AS poller_id FROM httptest LIMIT 10;
     httptestid | poller_id
             23 |         3
             17 |         1
             20 |         0
             16 |         0
             18 |         2
             19 |         3
             22 |         2
             21 |         1
              9 |         1
              7 |         3
    (10 rows)
    zabbix=#
