Map hanging.
  • TQ72
    • Jul 2012
    Map hanging.
    2.0.3 running on Ubuntu
    Have created one map which used to work ok, but now when clicking on the maps tab on monitoring page, it just sits there attempting to connect.
    I am able to view and edit the map under configuration and when I delete the map completely I am able to navigate normally, except I get the message no maps defined - obviously.
    I am able to import the map again, and then get the same problem. I dont really want to create the map again from scratch, but there is something within this map that isnt liked. Any way of finding out what the offending item is?? I suspect this started to happen after playing around with the export/import function but cant be sure.
    Any help appreciated.
    Regards,
    TQ.
  • TQ72
    • Jul 2012
    One problem solved...
    Gave up on this in the end and rebuilt the server and restored database. Maps are ok now but have an issue doing anything with restored database - save, clone, delete. Grr
    • mbsit
      • Sep 2012
      • 130
      Did you check different web browser?
      I got the same issue on Firefox, but not in IE.
      Bests,
      Grzegorz
      Wdrożenia Zabbix - Warszawa
      Pozdrawiam
      Grzegorz Grabowski
      ____
      WdroĊĵenia, szkolenia, umowy serwisowe
      Warszawa - Polska
