Help with template in 2.0.3
  • Jairo
    • Nov 2012
    Hello all.
    I'm new into Zabbix and I need to monitor some servers and network devices, one of them is a Router Cisco 7206, I found the template in the Wiki, but I can't figure out how it works.
    Do I need to change some parameters of the XML file in order to get it working with my router modules?
    Example: my router has serial interfaces and in the XML are Gi0/1.
    Can somebody explain a kind of HOWTO, from how to get the template and configure into Zabbix.
    NOTE: I'm using version 2.0.3
    Thanks.
    Jairo
