Asterisk call monitoring
  • zozo
    • Nov 2012
    I am setting up an asterisk call monitoring on zabbix 2.0.3. in the zabbix_agentd.conf I have set up the following command:
    UserParameter=asterisk.calls,UserParameter=sudo asterisk -rvvvvvx 'core show channels'|grep --text -i 'active call'|awk '{print $1}'
    then I set up an item and the asterisk is running the command I am always getting in the log the following
    16422:20121108:062900.426 In substitute_key_macros() data:'asterisk.calls'
     16422:20121108:062900.426 End of substitute_key_macros():SUCCEED data:'asterisk.calls'
     16422:20121108:062900.426 In get_value() key:'asterisk.calls'
     16422:20121108:062900.426 In get_value_agent() host:'Hostname' addr:'XX.XX.XXX.XX' key:'asterisk.calls'
     16422:20121108:062900.428 Sending [asterisk.calls
    Please guide me make this work.
    thanks.
  • Colttt
    • Mar 2009
    • 878
    do you try this command as zabbix-user?!
    Debian-User
    Sorry for my bad english
    • zozo
      • Nov 2012
      zabbix@hostname:/$ sudo asterisk -rvvvvvx 'core show channels'|grep --text -i 'active call'|awk '{print $1}'
      4
      it works correctly.
      • zozo
        • Nov 2012
        6
        Apparently works on the zabbix user.
        • kazuki
          • Oct 2012
          did you try if other parameters work?
          try it
          UserParameter=asterisk.calls,echo hello >> /var/log/test
          • zozo
            • Nov 2012
            I've changed the script a little bit by replacing the awk with the cut command and it works now.
            Thanks for your help anyone
