Zabbix 2.0.3 - escalation - how to set it?
  • ufocek
    • Aug 2006
    • 161
    I want to set a actions together with ecalation. I want to create a 5 steps.
    1 - immediately
    2 - 3 - notification every 1h
    4 - if problem exist over than 5h
    5 - if problem exist over than 10h
    Steps settings:
    1) immediately
    2-3) in action "default operation step duration" I set to 3600, I get two notification e.g 2:00 pm, 3:00 pm
    4) I want to set nofication after 10h so I put in step duration "18000s", but then in steps 2-3 "start in" is changing to "05:00:00".
    Is it possible to set it up in 5 steps or I must count the step where I'll have a notification after 10 hours?
  • heaje
    • Sep 2009
    • 325
    Check out this page in the Zabbix wiki/docs:
    http://www.zabbix.com/wiki/howto/config/alerts/delaying_notifications
