SNMP Template
  • JDNight
    • Nov 2006
    • 15
    SNMP Template
    I'm looking to do something with a zabbix template, and I'm not sure how to do it.
    I want to build a template that uses SNMP to find the interface name (ifDescr) and then use that name with Ingress and Egress monitoring items.
    Example: Interface name is WAN 2 and the data in / out would be named WAN 2 data in and WAN 2 data out.
    I would imagine it would look something like this in the template:
    {template:Firewall_ifdesrc1} Ingress
    Not certain if this would be done with discovery or some other options to make this work.
  • joe.thomas
    • Nov 2012
    You would want to use discovery rules. Use the SNMP Interfaces template as a model, it already discovers interfaces, you just need to change the item prototypes to match what you need.
