problems monitoring log files
  • Pablo
    • May 2006
    • 24
    I don't be able to monitor log files. Somebody can help me???
    I have installed correctly de agent.
    This the most important parameter of the zabbix_agentd:
    Hostname=localhost.localdomain
    #(it's the same name of the host created in zabbix frontend)
    #DisableActive=1
    #EnableRemoteCommands=1
    #(this lines are comments).
    I create this item:
    Description: syslog
    Type:zabbix agent
    key:log[/var/log/syslog]
    Type of information:log
    zabbix agent can make: tail -f /var/log/syslog
    When I save the item I get this message:
    Parameter [log[/var/log/syslog]] is not supported by agent on host [localhost.localdomain] Old status [0]
    Pablo
  • Alexei
    Founder, CEO
    • Sep 2004
    • 5654
    Change type to 'ZABBIX agent (active)" to make it work.
    Alexei Vladishev
    New York | Tokyo | Riga
    My Twitter
    • Pablo
      • May 2006
      • 24
      Thank you.
