Triggers on SNMPTraps in Zabbix 2 (using perl receiver script)
  • Jason
    • Nov 2007
    • 431
    I've got the traps coming into zabbix using the perl receiver script...
    12:59:51 2012/11/14 PDU INFO:
    notificationtype TRAP
    version 1
    receivedfrom UDP: [XXX.XXX.XXX.XXX]:22252->[XXX.XXX.XXX.XXX]
    errorstatus 0
    messageid 0
    community public
    transactionid 10
    errorindex 0
    requestid 7
    VARBINDS: DISMAN-EVENT-MIB::sysUpTimeInstance type=67 value=Timeticks: (0) 0:00:00.00
    SNMPv2-MIB::snmpTrapOID.0 type=6 value=OID: SNMPv2-SMI::enterprises.24769.100.100.100.0
    SNMPv2-SMI::enterprises.24769.100.200.1.0 type=4 value=STRING: "Information"
    SNMPv2-SMI::enterprises.24769.100.200.2.0 type=4 value=STRING: "I00640000:All events"
    On the above data what can the trigger be configured on? Is it just searching the whole lot as a string match or can I run it on, for example the severity, which is Information in this case?
  • Jason
    • Nov 2007
    • 431
    I can't see a way to filter on the info in the VARBINDS section of the trap info... Is this assigned to values/macros that we can compare contents of or is the entire field just text that need to match, for example..
    Jason
    • Jason
      • Nov 2007
      • 431
      Does anyone have any information on this?
      From the documentation at http://www.zabbix.com/documentation/...types/snmptrap it says that perl is the recommended method on production systems, but information on it is sketchy... For the SNMPTT I can see that each event needs to be configured, but the perl receiver just passes the lot across.
      Therefore I can select the snmptraps for the specific application by setting the key as the snmtrap["OID for the APP"]
      However, is the information just stored in zabbix as plaintext as displayed? Surely it would be useful to pull out the status field as a severity and be able to use that as a filter?
