Like many things in zabbix, use of zabbix_sender is talked about alot, but nowhere in the documentation is it actually explained how to use it. (Or if it is, it's hidden somwhere obscure)
I've read a lot of posts for various versions of zabbix, some say use zabbix_sender with zabbix_trapperd (which is also not explained well), others don't mention trapperd at all and just say "send your information to your server."
I understand that you use a script (or some method of gathering the information and present this to zabbix_sender, but how do you set up the interaction with the server?
What is the comand line syntax for zabbix_sender?
What do you need to do on the server side to get the information into an Item?
A detailed description with an example would be great.
Thanks,
Daniel
Thanks,
Daniel
