I'm having an issue with Mounted filesystem discovery. In the template OS Windows there is a discovery rule that finds all drives on the host. On these discovery rules there are trigger prototypes. They create a trigger for every detected drive.
We have a host with a pagefile partition, which is always filled - less then 2% free. I would like to disable the trigger for this single partition on this single host.
However, if I disable the trigger, the trigger gets disabled for all drives on this host.
Is there a way to disable this trigger for a single host, for a single drive?
tnx,
Sven.
tnx,
Sven.
