Discovery with filter SNMP OID
  • bobyboy
    • Nov 2012
    • 25
    Hi all,
    I want to create a "SNMP discovery" back to the "ifInOctets" and "ifOutOctets" for only my interfaces with "ifOperStatus = up" OID value.
    Do you have a track to help me.
    Thank you.
    My config :
    I have :
    - Create one template with one discovery
    * Discovery :
    Name : Network interface up
    Type : SNMPv2 agent
    key : snmp.discovery
    SNMP OID : ifOperStatus
    SNMP community : ****
    Filter macro : {#SNMPVALUE} Regxp : ^up$
    - Create item prototypes :
    Type : SNMPv2 agent
    Key : ifInOctets[{#SNMPINDEX}]
    SNMP OID : ifInOctets.{#SNMPINDEX}
    And with this config, all my interface network are discovery.
  • pcraponi
    • Oct 2012
    • 15
    I need the same thing... If you found the solution, please share here..
    Thanks.
    Best Regards,
    Paulo Raponi
    • bobyboy
      • Nov 2012
      • 25
      Solution : just change the regxp : "^u|^1"
      Snmp retunr value "up (1)" so i use this 2 filter.
      • pcraponi
        • Oct 2012
        • 15
        Thanks. I did this... Works..
        What you do now to get the network interfaces name? With this item, I can only get the index of the interface, not the name. Can we do a correlation between the name and the index?
        My SNMPWalk returns:
        IF-MIB::ifOperStatus.25 = INTEGER: up(1)
        IF-MIB::ifOperStatus.26 = INTEGER: up(1)
        IF-MIB::ifOperStatus.27 = INTEGER: up(1)
        IF-MIB::ifOperStatus.28 = INTEGER: up(1)
        IF-MIB::ifOperStatus.29 = INTEGER: up(1)
        IF-MIB::ifOperStatus.30 = INTEGER: up(1)
        How I can get the name to put on graphs?
        Regards,
        Paulo Raponi
        • bobyboy
          • Nov 2012
          • 25
          I see we have the same point
          At first I tried to add an item to back ifDescr OID, but impossible to integrate these data in the name of my graphs.
          This highly requested feature will probably be available in the next version, see my last post http://www.zabbix.com/forum/showthread.php?t=37727
          A++
