Problem with monitoring DB2 with dbforbix
  • zaicnupagadi
    • Dec 2010
    • 73
    Hi all,
    We are struggling to force working our dbforbix with DB2 database (TSM 6)
    We are receiving a strange error in dbforbix.log:
    2012-12-05 00:53:37,767 [main] ERROR DBforBIX - Error on Configurator for database DB2DB5 -->DB2 SQL error: SQLCODE: -104, SQLSTATE: 42601, SQLERRMC: END-OF-STATEMENT;SELECT SYSTEM_USER;<table_expr>
    It seemes that dbforbix has the initiate the first contact with the database. As we have searched throught the Internet that kidn of error is for - as arror says itself - wrongly terminated line (at least the first SQLERRMC says that), all we try to ask for tests is:
    QueryList=test
    test.Query=SELECT buff_hit_ratio FROM TSMDB1.DB
    I have read that the problem may occur when there are some ")" in query, but ours is as easy as pie, it should pass with no problem.
    I would like to add that Oracle database is monitored properly - dbforbix is connecting to it easily.
  • handerson
    • Aug 2013
    error
    we´re testing DBForbix to monitor a DB2 Database, but in dbforbix.log we are receiving this error on log:
    2013-08-16 09:56:12,477 [main] ERROR DBforBIX - Error on Configurator for database server197 -->DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=END-OF-STATEMENT;SELECT SYSTEM_USER;<table_expr>, DRIVER=3.53.95
    This is the code of db2Query.props:
    #DefaultQueryPeriod=2
    QueryList=tbsutilization
    #statistic of database
    tbsutilization.Query=select substr(tbsp_name,1,10) "Name", tbsp_utilization_percent "Used%", tbsp_free_pages "FreePages", tbsp_usable_Pages "UsablePages", tbsp_used_pages "UsedPages", tbsp_page_top "HWM", tbsp_auto_resize_Enabled "AutoResize 1=Yes", tbsp_increase_size "Increase Size", tbsp_max_size "MaxSizeBytes -1=ulimited", tbsp_last_resize_failed "ResizeFailed 1=Yes", tbsp_page_size "PgSize Bytes" \
    from SYSIBMADM.TBSP_UTILIZATION \
    where tbsp_type = 'DMS'
    tbsutilization.NoDataFound=non
    Could you help us?
    Thanks in advance!
    • johansen
      • Oct 2009
      • 38
      was anybody able to solve this? Have exactly the same problem:
      error:
       2014-02-28 16:12:28,379 [main] INFO  DBforBIX - Starting DBforBIX Version 0.6.1
       2014-02-28 16:12:28,389 [main] INFO  DBforBIX - DBforBIX started with pid:18868
       2014-02-28 16:12:28,390 [main] INFO  DBforBIX - PidFile -> ./logs/dbforbix.pid
       2014-02-28 16:12:28,936 [main] ERROR DBforBIX - Error on Configurator for database DB2DB1 -->DB2 SQL Error: SQLCODE=-104, SQLSTATE=42601, SQLERRMC=END-OF-STATEMENT;SELECT SYSTEM_USER;<table_expr>, DRIVER=3.63.75
       2014-02-28 16:12:28,936 [main] INFO  DBforBIX - This Database DB2DB1 removed
       2014-02-28 16:12:28,937 [main] ERROR DBforBIX - ERROR on main - Connections is empty
      config:
      ###DB2
      #define here your connection string for each database
      #on the following example we are treating DB2
      DB2DB1.Url=jdbc:db2://hostname.domain:50000/databasename
      DB2DB1.User=zabbix
      DB2DB1.Password=passwordofzabbixuser
      DB2DB1.DatabaseType=db2
      DB2DB1.QueryListFile=./conf/db2query.props
      • s4chin
        • Mar 2014
        Db4bix
        Hi Frnds,
        I have zabbix server on 192.168.0.162 (CentOS 6.5). Zabbix version is 2.2.1.
        My Oracle server (10.2.0.5) is on 192.168.0.244. So i installed orabbix 1.2.3 on oracle server in /opt directory and i think it is working ok. I imported oracle template "Orabbix_export_full.xml" from orabbix template folder in zabbix server and added host also...but there is no data on zabbix server related to oracle template
        My files config are :
        1 ) config.props
        ZabbixServerList=ZabbixServer1
        ZabbixServer1.Address=192.168.0.162
        ZabbixServer1.Port=10051
        OrabbixDaemon.PidFile=./logs/orabbix.pid
        OrabbixDaemon.Sleep=300
        OrabbixDaemon.MaxThreadNumber=2
        DatabaseList=DB1
        DatabaseList.MaxActive=10
        DatabaseList.MaxWait=100
        DatabaseList.MaxIdle=1
        DB1.Url=jdbcracle:thin:@192.168.0.244:1521rclt est10g
        DB1.User=zabbix
        DB1.Password=zabbix
        DB1.MaxActive=10
        DB1.MaxWait=100
        DB1.MaxIdle=1
        DB1.QueryListFile=./conf/query.props
        2) orabbix.log
        2014-03-08 10:23:57,935 [main] INFO Orabbix - Starting Orabbix Version 1.2.3
        2014-03-08 10:23:57,989 [main] INFO Orabbix - Orabbix started with pid:5099
        2014-03-08 10:23:57,989 [main] INFO Orabbix - PidFile -> ./logs/orabbix.pid
        2014-03-08 10:23:58,434 [main] INFO Orabbix - DB Pool created: org.apache.commons.dbcp.datasources.SharedPoolData Source@7a3f437c
        2014-03-08 10:23:58,434 [main] INFO Orabbix - URL=jdbcracle:thin:@192.168.0.244:1521rcltest1 0g
        2014-03-08 10:23:58,434 [main] INFO Orabbix - maxPoolSize=10
        2014-03-08 10:23:58,435 [main] INFO Orabbix - maxIdleSize=1
        2014-03-08 10:23:58,435 [main] INFO Orabbix - maxIdleTime=1800000ms
        2014-03-08 10:23:58,435 [main] INFO Orabbix - poolTimeout=100
        2014-03-08 10:23:58,435 [main] INFO Orabbix - timeBetweenEvictionRunsMillis=-1
        2014-03-08 10:23:58,435 [main] INFO Orabbix - numTestsPerEvictionRun=3
        2014-03-08 10:24:02,369 [main] INFO Orabbix - Connected as ZABBIX
        2014-03-08 10:24:02,376 [main] INFO Orabbix - --------- on Database -> orcltest
        2014-03-08 10:24:04,576 [pool-1-thread-1] INFO Orabbix - Done with dbJob on database DB1 QueryList elapsed time 1988 ms
        2014-03-08 10:25:02,665 [pool-1-thread-2] INFO Orabbix - Done with dbJob on database DB1 QueryList elapsed time 31 ms
        Why there is no data on zabbix server
        • kunajn
          • Jan 2012
          error:
          I have the same problem. And it seems to be problem with the source code, in the /com/smartmarmot/common/Constants.java:
          public static final String DB2_VALIDATION_QUERY = "SELECT 1";
          public static final String DB2_WHOAMI_QUERY = "SELECT SYSTEM_USER";
          public static final String DB2_DBNAME_QUERY = "SELECT @@SERVERNAME";
          These queries won't work with DB2. It should be something like this:
          public static final String DB2_VALIDATION_QUERY = "SELECT CURRENT DATE FROM SYSIBM.SYSDUMMY1";
          public static final String DB2_WHOAMI_QUERY = "SELECT CURRENT USER FROM SYSIBM.SYSDUMMY1";
          public static final String DB2_DBNAME_QUERY = "SELECT CURRENT SERVER FROM SYSIBM.SYSDUMMY1";
          BTW - I wish Andrea had more time and willingness to develop this great tool...
          • kunajn
            • Jan 2012
            FYI - I changed these queries, recompiled dbforbix and it's working with DB2 now...
             2014-07-21 16:53:37,626 [main] INFO  DBforBIX - DBforBIX started with pid:32067
             2014-07-21 16:53:37,626 [main] INFO  DBforBIX - PidFile -> ./logs/orabbix.pid
             2014-07-21 16:53:37,751 [main] ERROR DBforBIX - Error on Configurator for database DB2DB5 -->DB2 SQL error: SQLCODE: -104, SQLSTATE: 42601, SQLERRMC: END-OF-STATEMENT;SELECT SYSTEM_USER;<table_expr>
             2014-07-21 16:53:37,751 [main] INFO  DBforBIX - This Database DB2DB5 removed
             2014-07-21 16:53:37,751 [main] ERROR DBforBIX - ERROR on main - Connections is empty
             2014-07-21 16:56:07,451 [main] INFO  DBforBIX - Starting DBforBIX Version 0.6.1
             2014-07-21 16:56:07,457 [main] INFO  DBforBIX - DBforBIX started with pid:15045
             2014-07-21 16:56:07,457 [main] INFO  DBforBIX - PidFile -> ./logs/orabbix.pid
             2014-07-21 16:56:07,618 [main] INFO  DBforBIX - Connected as ZABBIX
             2014-07-21 16:56:07,619 [main] INFO  DBforBIX - --------- on Database -> SAMPLE
             2014-07-21 16:56:07,721 [pool-1-thread-1] INFO  DBforBIX - Done with dbJob on database DB2DB5 elapsed time 48 ms
             2014-07-21 16:57:07,676 [pool-1-thread-2] INFO  DBforBIX - Done with dbJob on database DB2DB5 elapsed time 2 ms
             2014-07-21 16:58:07,679 [pool-1-thread-3] INFO  DBforBIX - Done with dbJob on database DB2DB5 elapsed time 4 ms
            • rajans
              • Jul 2015
              Trying to setup DB2 monitor
              I am trying dbforbix for db2, could you please share the code. Thanks.
              • rajans
                • Jul 2015
                db2bix error, please help
                Prop Conf:
                SAMPLE.Url=jdbc:db2://192.168.4.40:50001/SAMPLE
                SAMPLE.User=zabuser
                SAMPLE.Password=ZABBIX
                SAMPLE.MaxActive=10
                SAMPLE.MaxWait=100
                SAMPLE.MaxIdle=1
                SAMPLE.DatabaseType=db2
                QueryListFile=/opt/db2bix/conf/query.props
                DB2bixDaemon.PidFile=./logs/db2bix.pid
                DB2bixDaemon.MaxThreadNumber=100
                LOG:
                2015-07-28 23:33:48,410 [main] INFO DB2bix - Starting DB2bix Version 1.2.0 RC1
                2015-07-28 23:33:48,442 [main] INFO DB2bix - DB2bix started with pid:3803
                2015-07-28 23:33:48,442 [main] INFO DB2bix - PidFile -> ./logs/db2bix.pid
                2015-07-28 23:33:48,443 [main] DEBUG DB2bix - getConnection for database SAMPLE
                2015-07-28 23:33:49,518 [main] ERROR DB2bix - Error on Configurator for database SAMPLE -->Could not retrieve connection info from pool
                2015-07-28 23:33:49,518 [main] INFO DB2bix - This Database SAMPLE removed
                2015-07-28 23:33:49,518 [main] ERROR DB2bix - ERROR on main - Connections is empty or null
                2015-07-28 23:33:49,535 [main] INFO DB2bix - New database founded! SAMPLE
                2015-07-28 23:33:49,535 [main] DEBUG DB2bix - getConnection for database SAMPLE
                2015-07-28 23:33:50,111 [main] ERROR DB2bix - Error on Configurator for database SAMPLE -->Could not retrieve connection info from pool
