Triggers Expression Performance
  • eterjack
    • Mar 2012
    • 60
    Hello, I'm considering using the trigger expression min (86400), triggers to generate change in the severity of the event, for example:
    High Severity: min (5m)
    Problem Severity: min (3600m)
    I'm wondering, can I have a performance problem by doing this. What do you think? Do you have any other ideas?
