I just found out about Zabbix and because i think it is a great tool...I wanted to install it. However I found the installation kind of confusing..so I want to ask you guys some questions:
The project that I work on is in PL/SQL and I have an oracle database which runs on a Windows7 server...
1. At the download page, http://www.zabbix.com/download.php i see that for windows you only have "agents".. and Zabbix Sources
(Server, Proxy, Agent, GUI) are a .tar file..so they can only be used on linux...SO can you only install zabbix on linux?
2. What are the agents for?
