I have question where to get bandwitch statistic for each host/interface in zabbix database. What I found is history, history_uint, trends, trends_uint. Trends and trends_uint looks like have stats which are showing on the graphics but I see that this value is saving each hour and has min, avg and max. So it looks like calculated subtotal per each hour. From other side, history and history_uint has more clock points (each 5 seconds as I see) but it doesn't look to be saving for all date periods - just short period. Can you help me understand it please?
Also what is difference between history and history_unit, for example?
Thanks,
Alex
Thanks,
Alex
