monitoring traffic usage on x.x.x.x/mask
  • seccentral
    • Dec 2012
    Hi, i recently(today) heard about this open source solution while looking for some means to monitor the traffic per ip on a gateway router running linux.
    So i got the virtual appliance, deployed in vsphere but got a lil dazed by it's complexity.
    My goal is to monitor traffic in/out (not graph the speeds, but log the total data in bytes/mbytes etc, for a vps project that has customers limited to specific sizes: for example: 1000GB/month etc)
    Basically from what i've seen so far this project is in theory something similar to nagios. more or less. anyway that's not the point here.
    On a linux router that i install zabix, can i monitor the total/in/out traffic that passes through that router but specific to a network/mask filter ?
    and get the statistics per each and every one ip address from within that ip network ?
    So far i've tried bandwidthd, ntop, darkstat but i'm always exploring alternatives.
  • BDiE8VNy
    • Apr 2010
    • 680
    One way could be to use iptables.
    This is only an example to show the idea and should not be considered as a ready-to-use solution.
    First a new chain "traffic-monitor-net1" is created which gets all the traffic that is forwarded from the network 192.168.1.0/24.
    Then a rule that only matches traffic coming from the address 192.168.1.42 is added to the new chain.
    [root@router ~]# iptables -N traffic-monitor-net1
    [root@router ~]# iptables -A FORWARD -s 192.168.1.0/24 -j traffic-monitor-net1
    [root@router ~]# iptables -A traffic-monitor-net1 -s 192.168.1.42
    [root@router ~]#
    Now the bytes forwarded from 192.168.1.42 will be counted an can be monitored.
    [root@router ~]# iptables -L traffic-monitor-net1 -vnx
    Chain traffic-monitor-net1 (1 references)
        pkts      bytes target     prot opt in     out     source               destination
        5025 1099511691257            all  --  *      *       192.168.1.42          0.0.0.0/0
    [root@router ~]#
    One way to parse the output for transferred bytes could look like this
    [root@router ~]# iptables -L traffic-monitor-net1 -vnx | awk '$7=="192.168.1.42"{print $2}'
    1099511699843
    [root@router ~]#
    and can finally be used in a user parameter
    # Example for key: iptables.traffic.out["traffic-monitor-net1", "192.168.1.42"]
    UserParameter=iptables.traffic.out[*],/bin/sudo /sbin/iptables -L $1 -vnx | awk '$$7=="$2"{print $$2}'
    • gavind
      • Mar 2013
      • 59
      How about installing a program like iftop here, would it still work?
