problem with --enable-static
  • hilgmi
    • Dec 2012
    zabbix 2.4, gcc 4.7.1
    when --enable-static is used, configure fails:
    checking for the linux kernel version... unknown family (3.4.11-2.16-default)
    checking if static linking is possible... no
    configure: error: static linking is not possible on this system
    and in config.log:
    configure:7214: gcc -o conftest -g -O2 -rdynamic -static conftest.c -lm -lrt -lresolv >&5
    /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libm.a when searching for -lm
    /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: cannot find -lm
    /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/librt.a when searching for -lrt
    /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: cannot find -lrt
    /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libresolv.a when searching for -lresolv
    /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: cannot find -lresolv
    /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: skipping incompatible /usr/lib/libc.a when searching for -lc
    /usr/lib64/gcc/x86_64-suse-linux/4.7/../../../../x86_64-suse-linux/bin/ld: cannot find -lc
    tai
