system.hw.chassis
  • Zaniwoop
    • Jan 2010
    • 232
    system.hw.chassis
    I am trying to retrieve information about the hardware, using the zabbix agent system.hw.chassis key.
    If I use the command line
     zabbix_agent -t system.hw.chassis[model]
    I get a response
    system.hw.chassis[model]    [s|ProLiant DL360 G6]
    But the item I have created, with the key used above, returns ZBX_NOTSUPPORTED, both in Linux and Windows.
    The agent log (debuglevel=4) has this to say:
      3246:20130104:122643.454 Requested [system.hw.chassis[model]]
      3246:20130104:122643.454 Sending back [ZBX_NOTSUPPORTED]
    I am running version 2.0.4 on both the server and agents
  • tchjts1
    • May 2008
    • 1605
    I see the same issue.
    In the Wiki it shows this for that particular item: Root permissions are required because the value is acquired by reading from memory.
    Maybe that is the problem.
    • tchjts1
      • May 2008
      • 1605
      Yeah, I believe permissions are the issue.
      On my Zabbix server, if I run this as root I get the information:
      # zabbix_agentd -t system.hw.chassis[model]
      system.hw.chassis[model] [s|VMware Virtual Platform]
      But if I run it as zabbix user, I get this:
      $ zabbix_agentd -t system.hw.chassis[model]
      system.hw.chassis[model] [m|ZBX_NOTSUPPORTED]
      • Zaniwoop
        • Jan 2010
        • 232
        Ok... What's the solution for Windows Servers?
        • chopeta
          • Feb 2013
          I am trying to accomplish this in my linux servers and I am getting only ZBX_NOTSUPPORTED.
          Were you guys able to implement this?
          Do anybody else knows exactly what are the steps to make key
          "system.hw.chassis" work on zabbix_agentd?
          As root:
          system.hw.chassis [s|Dell Inc. PowerEdge 1950 XXXXXXX Rack Mount Chassis]
          As zabbix:
          # su -s /bin/sh zabbix -c "zabbix_agentd -t system.hw.chassis"
          system.hw.chassis [m|ZBX_NOTSUPPORTED]
          I am using Zabbix 2.0.5 on both server and agent (provided by ZabbixZone Repo).
          Same problem with Ubuntu and stable agent 2.0.4
          I've tried changing /etc/sudoers in a lot of diff. ways without any luck.
          Any help is deeply appreciated.
          • harmonica
            • Jan 2009
            • 251
            You could try and change in zabbix_agentd.conf the "Option: AllowRoot"
            Regards
            • Zaniwoop
              • Jan 2010
              • 232
              Yes, on the Linux hosts, you need to add
              AllowRoot=1
              to the zabbix_agentd.conf file
              • chopeta
                • Feb 2013
                Thank you so much guys!
                AllowRoot did the trick.
                Best regards,
                chopeta
                • Zaniwoop
                  • Jan 2010
                  • 232
                  Now, if only we can get the same information for Windows devices....
                  • davidex
                    • Nov 2022
                    Now i have the same problem still with Windows devices, do you guys have find out some solution?
                    • geoffke
                      geoffke commented
                      Just use this:
                      Serial: wmi.getall[root\cimv2,"SELECT serialnumber FROM WIN32_BIOS"]
                      Model: wmi.getall[root\cimv2,"SELECT model FROM Win32_COMPUTERSYSTEM"]
                      Have a look at the WMI queries, you will see there is much more information which can be gathered
                  • Hamardaban
                    • May 2019
                    • 2713
                    RTFM !
                    https://www.zabbix.com/documentation...ystem.hw.chass
                    system.hw.chassis[<info>]
                    Chassis information. String info - one of full (default), model, serial, type or vendor Supported platforms:
                    Linux.
