Userparameter command status code not being picked up correctly.
  • andre@andaff.com
    • Jan 2013
    Hoping someone can shed some light on this and maybe provide an easy solution to monitoring software raid configs.
    Some Details
    Zabbix server= 2.0.2
    Zabbix Client = same
    I am a long time user of zabbix since the pre 1.0 versions and in the past created scripts for many of my custom checks, recently I have started using puppet for server builds and have moved to using zabbix userparameters in the zabbix_agentd.conf for any custom checks because it was easy to build a zabbix module that auto created the zabbix_agentd.conf with a new server build and to use host exceptions in the erb template to create a host specific zabbix conf. (probably too much info but I am not looking for a workaround scripting solution for my problem).
    I am trying to monitor software raid arrays and the proper way to do this without using the mdadm --monitor feature is to use the following line.
    /sbin/mdadm --detail --brief --test /dev/md3 &>/dev/null;echo $?
    #the resulting command status code if 0 is an "OK Array", all other numbers reflect a different issue with the array.
    My problem is this command sends a 0 out at the command line but zabbix captures a 1. I would assume the command status code is reflecting something different.
    Here is my line in zabbix_agentd.conf
    UserParameter=it.raid1md3,/sbin/mdadm --detail --brief --test /dev/md3 &>/dev/null;echo "$?"
    Here is the output of debug on the server when it runs this command.
    Run remote command [/sbin/mdadm --detail --brief --test /dev/md3 &>/dev/null;echo $?] Result [1] [1]...
    3338:20130110:174423.113 Sending back [1]
    Hoping someone can point me in the right direction?
    Many thanks for any help to be had.
    Andre
  • Stephen Wood
    • Feb 2012
    • 43
    What happens when you give zabbix a shell and run the command manually?
    usermod -s /bin/bash zabbix
    You also might be able to get the info you need by running
    cat /proc/mdstat
    • andre@andaff.com
      • Jan 2013
      thanks that was it, the command required root access and I was forgetting the userparameters run as zabbix. The correct exit code was being displayed...the command was failing
      Guess I will need to use proc...not what I wanted but it is readable by everyone.
      Thanks again
      You Rock!
      Andre
