Some Macro substitution fail.
  • qlixed
    • Jul 2011
    Hello guys, i have a little issue with the macro substition, sometimes fails, without any logical pattern, AFAIK.
    Checking with debug mode i see this logs when the substition is made ok:
    http://pastebin.com/WFG9FL3M
    And when the substitution fails i get this logs:
    http://pastebin.com/U4d4uCyK
    As you can see this happens in the same host with a similar OID!.
    The issue here is that when a couple of SNMP fails (for a invalid community) the hosts go down.
    Someone have a similar issue? how can i debug this further?
  • qlixed
    • Jul 2011
    Forget it... i mess up the macro name: PEBKAC!
    So, always check:
    {$MACRONAME} is right!
    ${MACRONAME} is WRONG!.
