Platform: zabbix 2.0.3 running on Linux host.
Adding a host using template 'OS Linux' will populate items and triggers for this host. For example, for every filesystem, there's a trigger 'Mounted filesystem discovery: Free disk space is less than 20% on volume <volume>'.
How can I modify the trigger treshold for a specific file system (say '/back-up' can have less than 20% free space)? Since it is generated from a template, it cannot be modified. Is the only option creating a new trigger with a modified trigger expression? It would be nice to have a 'copy' option then...
Erik
Erik
