I'm pretty new to zabbix, I used it many years ago but not in great depth.
I have since moved back to it to monitor some windows servers I look after, I have setup all the basic checks like services stopping etc but I would like to monitor the backups.
All the servers use Acronis Backup & Recovery 11 and I have set them to write into the Windows Event log which they do.
The event source is: Acronis Backup and Recovery 11 Agent Core
The event ID is: 1
In the log details it displays "Error Code:12" for a successful backup.
How do I configure this item and trigger so that if the event log displays anything other than Error Code: 12 zabbix flags it as a problem?
Many thanks
Steve
The event ID is: 1
Many thanks
Steve
