Is it possible to clone a set of web checks between monitored hosts?
I have many web scenarios that I want to attach to each application host in a cluster. The URLs are different but the content checks are the same. If I could reset the host linkage after making the clone it would help a lot.
Of course it would be great if I could set the host portion of the URLs in the scenario to a macro value then it would be even simpler to change the cloned web check.
