I need to monitor the Brocade BR200E Switch. Currently I'm using Zabbix 1.8.11 and have not yet decided to upgrade to 2.0 as the system is working just fine.
Since there is no template available for the brocade switch I had a look at snmpbuilder, but this seems to be a very highly customized solution.
Is there something like snmpbuilder included in Zabbix 2.0 or does someone have a Brocade Template?
Regards,
Oliver
Regards,
Oliver
