Zabbix not sending SMS
  • clubbing80s
    • Sep 2005
    • 109
    Hi.
    I'm trying to configure sms alerts. I'm not receiving any alerts via SMS. When I look in the logs server are no references to GSM or SMS that I can see anywhere.
    I'm running Zabbix server v2.0.0 .
    I'm using a Nokia E93 via USU /dev/ttyACM0
    I have configured Media :
    Type: SMS
    Device: /dev/ttyACM0
    Enabled: yes
    I have configured my user to use SMS media for alerts 24/7 and all severity .
    So I'm a bit confused as to why this is not working or at least I'm not seeing something ins the logs.
    Any ideas ?
    Greg
  • vrtareg
    • May 2006
    • 293
    Hi
    I experienced the same issues one time with e-mail configuration.
    You can check for errors in "Administration -> Audit" and selecting "Actions".
    You will see if there any issues with not correct Media or User media assignment.
    Regards,
    Areg
    • clubbing80s
      • Sep 2005
      • 109
      Thank you for that .
      I see the cause:
      "error in open(/dev/ttyACM0): [13] Permission denied"
      Should be an easy fix.
      • develo999
        • Mar 2019
        • 17
        clubbing80s - long time but having same issue how did you fix it?
