Items and triggers for active checks
  • s0r1n
    • Feb 2013
    • 23
    I already tested, the active checks are working fine, for example I configured already the following item
    log["/var/log/messages","SEND FAX","UTF-8",200]
    and the corresponding trigger:
    {fax_server:log["/var/log/messages","SEND FAX","UTF-8",200].nodata(300)}=0
    I want to search for more keywords in the file and I defined more triggers for one item, here my example:
    {fax_server:log["/var/log/messages",,"UTF-8",200].str("SEND FAX")}=0
    {fax_server:log["/var/log/messages",,"UTF-8",200].str("SEND FAILED")}=0
    {fax_server:log["/var/log/messages",,"UTF-8",200].str("Document has been rejected")}=0
    but it seems my attempt failed, while the triggers do not collect data. Is there a way to use one item only or shall I define a new item for each new keyword? Please provide your opinion. Thanks, Sorin.
