how to get JMX information with Weblogic and Java 5
  • Maxone
    • Jan 2013
    Hi guys,
    I have a problem when i try to get the JMX information from Zabbix Client. What I did was the following:
    i modified the application startup script to add this parameters
    java -Dcom.sun.management.jmxremote.port=7091 -Dcom.sun.management.jmxremote.rmi.port=7191 -Dcom.sun.management.jmxremote.authenticate=false -Dcom.sun.management.jmxremote.ssl=false
    then i open thats port in the firewall.
    when i try to conect from Java Console to get the JMX information with the ip and the JMX port doesnt work.
    So i did a telnet ip 7091 and connected okay but
    when i telnet the second port (RMI) telnet ip 7191 it doesnt work, so this line is not working Dcom.sun.management.jmxremote.rmi.port=7191 - properly.
    So what i need is how can i configure the application to get the JMX information if i am working with Weblogic and Java 5?
    thank you in advance,
    best regards,
    Max
  • Bruno Carvalho
    • Oct 2014
    • 32
    See my article about...
    • Bruno Carvalho
      • Oct 2014
      • 32
      See if my article helps you: http://brunocarvalho.net/blog/2016/0...me-com-zabbix/
