Web Monitoring - ticket ID
  • pietro54
    • Feb 2011
    • 112
    Im looking for solution to monitor web services that send back ticket id after log on.
    Here`s the steps i need:
    1. http://site.com/webapi, ststus code 200, require - login
    2. Send login/password status code 200,
    webservice send me back my ticked ID
    3. Now I need to generate next link with that ticketID, it should look something like this:
    http://site.com/webapi?ticketID={myTICKET},getmyorders etc.
    My question is how to capture that ticketID and put in to my link automatically?
  • heaje
    • Sep 2009
    • 325
    I don't believe that web monitoring currently supports what you want it to do. You'll have to write a custom script that accomplishes what you want.
    • pietro54
      • Feb 2011
      • 112
      Thanks heaje for reply,
      maybe some one else got same type of problem?
      • danrog
        • Sep 2009
        • 164
        Take a look at my post
        • NgRox
          • Jun 2022
          • 45
          You can use an item like zabbix agent and run the commands (If running on Linux):
          system.run['teste=$(curl -x GET https://url/ | jq .id) && curl https://url...id=$teste//)']
          Basically you run a remote command: system.run
          It runs a curl that generates the ID and saves it in a variable called test: curl -x GET https://url/ | jq .id --- (note that jq .id is the treatment of the result to obtain the id number without anything else)
          If this first command is executed successfully, it will run the second: &&
          The second will be a CURL in the other url and now you can pass the id that is saved in the test variable: curl https://url...id=$teste/
