Launch trigger when down five minutes
  • theboina
    • Feb 2013
    • 10
    The default trigger alert you when a service is down (eg BASIC App {Template: net.tcp.service [ssh]. Last (0)} = 0)
    How can I indicate that launch the trigger if host takes the down (state 0) more than 5 minutes?
    Thanks .
  • Michael0
    • Jan 2013
    • 70
    you have to link it with "&"
    e.g:
    {Template: net.tcp.service [ssh]. Last (0)} = 0) & {Template: net.tcp.service [ssh]. Avg (300)} = 0)
    So if the average value for the last 300sec (5min) = 0 then the trigger will be launched.
    this should work for you
    • theboina
      • Feb 2013
      • 10
      And only with {Template: net.tcp.service [ssh]. Avg (300)} = 0) doesn't works??
      Thx
      • harmonica
        • Jan 2009
        • 251
        BASIC App {Template: net.tcp.service [ssh].min(5m)} = 0)
        • anjiytwok
          • Dec 2012
          • 44
          Can any one careated events based on the trigger? so that we can notify the emails?
          • Slash
            • May 2011
            • 64
            Don't forget the nodata function!
            Example for an alert after 4 minutes of no data for an item :
            {Linux:system.cpu.util[,idle].nodata(4m)}=1
            • anjiytwok
              • Dec 2012
              • 44
              one question:
              I saw couple of things to work the eventa based on the triggers. we need to set the media option( let say email)
              1.SMTP server
              2. SMTP helo
              3. SMTP email
              Could you please suggest me, what I need to do to check my emails triggering option to work
              • tim.mooney
                • Dec 2012
                • 1437
                I don't think that's correct for a service check, harmonica.
                That will trigger an event if the minimum value is 0 in the last 5 minutes. Assuming you're checking once a minute, then only one of the 5 checks needs to be 0 for that to trigger.
                Either using .max(5m) # 1 or .avg(5m) = 0 should work better, I think.
                • m_gularte
                  • Jul 2012
                  • 85
                  Hi!
                  I suggest:
                  .sum(#5)}=0
                  or
                  .sum(300)}=0
                  • theboina
                    • Feb 2013
                    • 10
                    Thanks a lot...
                    • jdurga
                      • Dec 2018
                      • 10
                      Hello all,
                      I must be doing something wrong.
                      {(EXAMPLETEMPLATE):Temp.last(0)}>72 & {(EXAMPLETEMPLATE):Temp..min(5m)} = 0)
                      This is a temp monitor, needs to trigger when over 72 F and when it's been more then 5 minutes.
                      Thank you.
