I would like to use Zabbix to monitor availability and battery status of a large group of "sensors" that do not speak SNMP. I've created a custom MIB which contains a SNMP table (each row represents a sensor) and a couple of traps for low battery etc. The MIB is implemented by a custom agent on a central server knows the current status of all the sensors.
Querying the SNMP table works great and so does sending traps. But the traps are not very useful in Zabbix because they all originate from the same host (the central server). This means that I cannot acknowledge a low battery trap for a specific sensor etc.
All traps contain the sensor unique serial number in a varbind, which I assumed could be used to correlate traps somehow. But I realize now that it would require some "virtual device" concept in the SNMP manager.
Has anybody done something similar? Is Zabbix the right choice for me or should I look into other options?
