Timeline - less period then 1h in Zabbix 2.0.4
  • pietro54
    • Feb 2011
    • 112
    I need to watch one of my graphs in less period then 1h, so i allways edit file:
    /var/www/html/js/gtlc.js
    change minperiod to 600sec, and it helps.
    But now, in new version, 2.0.4 it isent so easy,
    Im getting error like this:
    ERROR: Page recived incorrect data
    Warning. Incorrect value from field "period": must be between 3600 and 63072000
    did any one try to change this parameter?
  • heaje
    • Sep 2009
    • 325
    what happens if you try and change the ,minimum period in defines.Inc.php?
    • pietro54
      • Feb 2011
      • 112
      damn, ur right.
      I totaly forgot about it...
      Thank you
      • Slash
        • May 2011
        • 64
        Very useful tip!
        I didn't know it was possible to change the one hour minimal period.
        • pietro54
          • Feb 2011
          • 112
          yes, You can create something like live graph.
          I watch connection to my web site, its refreshed every 5sec.
