Upgrade options
  • KarmaPolice
    • Oct 2005
    • 95
    Upgrade options
    Rather than upgrade i was wondering how easy it is to do a clean install and then simply export the old data into the new database...
    i know this is probably somewhat tricky because of db changes through the versions, but i was hoping someone may have done it before and so might be able to help.
    Thoughts?
