macro like $1 in trigger name but for key parameter?
  • tim.mooney
    • Dec 2012
    • 1436
    I'm using Zabbix 2.0.4.
    I know that $1 through $9 can be used in trigger names to reference *constants* in the trigger expression, as described in the 2.0 manual.
    That's very useful, but what I'm wondering is if I there is a way to use macros to match *parameters* to the item key.
    For example, if the trigger expression is
    {host.example.com:vfs.fs.size[/var,pused].last(0)}>98.0
    I know that "$1" evaluates to 98.0, however I'm looking for something like
    {HOST.NAME} {KEY1.PARAM1} full
    This would end up evaluating to
    host.example.com /var full
    Is there anything like that? I'm not seeing it and it seems like it would be very handy.
    Thanks,
    Tim
  • pintonunes
    • Feb 2010
    Hi Tim,
    Did you found the answer for your question?
    Thats a feature that I like to use very much now with LLD and everything new in 2.2.0.
    I have LLD for windows services and like to have an action to restart the service. But I need the service name. Service name is a parameter of the item...
    So I need something like "cmd /c net start {ITEM.KEY.PARAM}"
    Thanks,
    Pedro
