SMS not sending Expected [+CMGS: ] received [ERROR]
  • clubbing80s
    • Sep 2005
    • 109
    Hi.
    I'm using a Nokia E63 (bit of an overkill but its what the boss gave me for testing.)
    I don't receive any alerts via SMS, when I check in Audit Actions I see
    Expected [+CMGS: ] received [ERROR] and No media defined for user "Gregory Machin (greg.machin)" , when I check the user Gregory Machin , my mobile number is correct in my media settings.
    I tried this:
    AT+CMGF=1
    OK
    AT+CMGS="XXXXXXXX"
    > bobtb
    +CMGS: 1
    OK
    from one of the other posts to test if the E63 would send the sms and that worked.
    What have I missed ?
  • xanadu
    • Sep 2014
    • 62
    I have the same issue in zabbix v3.2.4.
    SMS notifications are enabled and configuration is correct. I can send SMS manually via minicom.
    Anybody knows why zabbix is declining SMS as media type?
