Help with notification email
  • Alex_SYB
    • Feb 2012
    • 133
    Hi
    I want to change the notification email so that you can click on a link that takes you to the acknowledgement page.
    would this work
    http://<myzabbix>/zabbix/acknow.php?eventid={EVENT.ID}&triggerid={TRIGGER.I D}
    thanks
    Alex
  • heaje
    • Sep 2009
    • 325
    Give it a try and see what happens . Just remove the extra space in {TRIGGER.ID} that you have in what you posted.
    • Alex_SYB
      • Feb 2012
      • 133
      Cool, works the charm
      • Alex_SYB
        • Feb 2012
        • 133
        is there any way to tell the end user how many notifications have been sent so far ?
        so I can put something like ...
        hey knuckle head this is the <X> time I have sent an email to you !
        • alledm
          • May 2012
          • 84
          This is what I have
          [{HOSTNAME}] {TRIGGER.NAME}: {STATUS} since {EVENT.AGE}
          I will keep alerting you every 12 hours unless acknowledged.
          Acknowledge: http://zabbix.XXXX.com/zabbix/acknow.php?eventid={EVENT.ID}
