More precisely maintenance like settings
  • daftu
    • Feb 2013
    • 15
    I need to set sth like maintenance time, because of about 15 minutes daily backup break of some services. Now I'm getting few emails about PROBLEMs with stopped services.
    I know there is solution setting maintenance period in Configuration-> Maintenance but it disables whole monitoring of given host(s) for 15 minites.
    I'd like to disable monitoring of given services (processes) instead of whole host.
    Is this possible? Maybe there is different functionality?
    I'm using Zabbix 2.0.
  • heaje
    • Sep 2009
    • 325
    As far as I'm aware, it is not possible to put a single item in maintenance. Only entire hosts can be put in maintenance.
    • danrog
      • Sep 2009
      • 164
      There is a way...
      Often host level maintenance is too much. Picture a machine running multiple services: While one service has a scheduled downtime, others continue their work and you want to be alarmed about them. Zabbix has no maintenance on trigger level at present, but you can work around it quite easily.   Traditional approaches: Define time spans […]
      • lukeiam
        • Sep 2012
        • 38
        Originally posted by danrog
        Good find. I love the maintenance mode but for me it still triggers all the triggers just without the notifications. I wish maintenance would disable triggers too as I always have to explain every event
        Regards,
        Luke
        • heaje
          • Sep 2009
          • 325
          Each user can customize the dashboard to exclude triggers that are in maintenance.
          • lukeiam
            • Sep 2012
            • 38
            Thanks! I will look into that.
