How prevent flapping triggers?
  • Tux
    • Jan 2010
    • 15
    how can i change my trigger to get only problem state, if problem still exist after X mins/checks?
    example Trigger:
    {Template DB Server:vfs.fs.size[{#FSNAME},pfree].last(0)}<5
    Im not really sure, how to use the "sum#" correctly:
    {Template DB Server:vfs.fs.size[{#FSNAME},pfree].sum(#3)}=0
    i want: if free space on #FSNAME ist under 5% about 3 checks, then alert this problem (want prevent flapping and a lot of OK,PROBLEM mails...). Or ist last(3)<5 better for this?
    can anyone help?
    thx
    PS: Ups, maybe wrong section. would it be better in "Zabbix Troubleshooting and Problems" ?
  • cferraro
    • Jun 2011
    • 16
    Tux,
    You may want to use the .count trigger function as described in
    Something like this should work for you:
    {Template DB Server:vfs.fs.size[{#FSNAME},pfree].count(#3,5,"lt")}>2
    This function returns the number of values which are less than 5 over the last 3 checks. If that number is greater than 2 it'll trigger.
    Basically, this would trigger if your last 3 checks were less than 5%.
    • Tux
      • Jan 2010
      • 15
      Thx m8, i will test it soon and report it here.
      • Michael0
        • Jan 2013
        • 70
        I had the same problem for our server, I solved it this way:
        For example with CPU utilization:
        {servername:system.cpu.util[,].avg(600)}>80
        If the average CPU utilization is higher then 80% for the last 10mins, then the trigger will alert me.
        Also you could use someting like this:
        {servername:system.cpu.util[,].last(0)}>80 &
        {servername:system.cpu.util[,].prev(0)}>80 &
        If the CPU utilization from the last and the previous check is higher than 80%
        Hope this helps
