Zabbix 1.1 installation
  • lobsw
    • Jun 2006
    I install Zabbix 1.1 on a Suse Linux 10.0 server. The installation seems go OK without any error messages. I can start the Zabbix_server program without any error and I can see processes use ps -A.
    After I modify the /include/db.inc.php, I copy the frontends/php directory to /srv/www/htdocs/zabbix subdirectory where the document_root of the apache 2.0 server is pointing as defauld. I also take the time to chmod all the php files to +x status. However, when I use a Web browse (Firefox) to browse the /localhost/zabbix subdirectory to look at the web interface to zabbix, I got a blank page. When I try to point to /localhost/zabbix/index.php, I got the same blank page.
    I am new to Zabbix and would like to set it up to monitor about 400 hosts devices. Could anybody tell me what did I do wrong ?
    lobsw
  • dantheman
    • May 2006
    • 209
    Just opening the local file will not work, since they are PHP files they need to be processed by a web server, eg Apache, it will need to be running and you need to view the frontend through that, rather than opening the files directly.
    • just2blue4u
      • Apr 2006
      • 347
      Erm... He has installed apache 2.0 ...
      Back to topic:
      Did you restart the Webs Server (apache)?
      Do the log files say anything?
      Have you tried to put a simple html-test-page into /localhost/zabbix/ ?
      Big ZABBIX is watching you!
      (... and my 48 hosts, 4513 items, 1280 triggers via zabbix v1.6 on CentOS 5.0)
      • lobsw
        • Jun 2006
        Installation of Zabbix 1.1
        1) Yes, I have reboot Apache after the installation. I also check all the processes is running OK using ps -A.
        2) I had check the zabbix_server.log. All process seems to run OK. There is a list server #9 to #10 started and no error message reported.
        3) I have put a dummy index.html page on the subdirectory and it load when I connect on http://localhost/zabbix. However, when I remove the dummy page. It give me a blank page again. I am not sure about PHP settings. But I have 3 more applications i.e. phpMyAdmin, Webmin and ipplan running on the same server under the same AMPP setting. I just want to add zabbix on the mix and it give me a blank page.
        Wonder if anyone could help.
        lobsw
        • just2blue4u
          • Apr 2006
          • 347
          what do the apache logs (error/access) say?
          • lobsw
            • Jun 2006
            I have check the Apache log. They complaint about errors in the PHP scripts. I am running PHP 5 with apache2.2 on my Suse 10.0 server. They complaint they couldn't find the /srv/www/htdocs/zabbix/include/config.inc.php.
            DO you think I should recopy the whole directory again?
